LS4 Performance - Ported Intake Manifold Installed!!!
Nick_Nasty's_GXP
04-09-2010, 04:28 PM
Alright so I got it installed today (took longer than I thought), and I did notice more throttle response. Being that my car in not tuned yet (maybe May??), I am expecting more from it once it does get tuned. I didn't really notice any sound differences, but I really wasn't looking for that anyway. I didn't really have enough time to take it out today, so I will reset my Maximum G's tomorrow and tell you of I saw any improvements. Other than that, this is what I noticed in my 3 mile drive home from the shop. Maybe once I get it tuned, and a couple more mods put on, I will notice more drastic changes. Does anyone else have the Ported IM who have noticed more gains??
-Nick
Model16
04-09-2010, 04:39 PM
Where'd you get it done?
ImpSS07
04-09-2010, 04:48 PM
I take it that you ported the stock manifold? How much did they port?
Nick_Nasty's_GXP
04-09-2010, 05:14 PM
K&M on William in Cheektowaga. They charged me 175 to install it. Took like 6 hours LOL.
I bought it from fastproms on ls1tech. I think the ad is still in the classifieds.
Mgpeagle
04-09-2010, 06:57 PM
You should get some rockers next. This woke my car up a lot...
-Mike
Nick_Nasty's_GXP
04-09-2010, 06:59 PM
-Mike
Which ones you got??
Mgpeagle
04-09-2010, 07:09 PM
I have SLP 1.85's. I found them in the classifieds here for 200.00. I also got some Intense oil restricted pushrods. I installed them with the rockers to prevent valve float since I used the stock springs. Those cost about 140.00 shipped and I have no valve float at all and they have been on there for about 10,000 miles now.
I am getting a ported intake as my next mod. Thank you for the review. That is the last piece of the puzzle for me.
-Mike
DavidGXP
04-09-2010, 09:30 PM
6hrs to install a intake! Took me less then an hour, and I ported mine myself.
Rockers are a must!
DieselPump
04-09-2010, 09:36 PM
nice, I'm thinking about getting a ported intake manifold and ported tb from them.
Or maybe the zzp tb that mgpeagle has.
Also rockers are next on the list for me as well!
GXP25
04-09-2010, 09:42 PM
I'd really like to see some gains from someone with a different camshaft.
DavidGXP
04-09-2010, 09:46 PM
Sittingmongoose, put down 286 with a ZO6 cam and cnc ported heads, with a ported intake. He later had a shop install a LS6 intake, and put down 313hp
Nick_Nasty's_GXP
04-10-2010, 04:58 PM
Rockers are a must!
Yeah. Well i didn't have tome to do it myself with school and work, but hey at least its done!
Mgpeagle
04-10-2010, 06:58 PM
I may be wrong, but isn't a Z-06 Cam too much for a 325? Getting rid of the cat and putting on the rockers really woke my car up on the top end and it is still a beast down low. I can't wait to get the proper tune once it is finished which will be in a month or two. I am also going to the track to see what she'll do. I hope it runs at the very least 13.2 or lower. I am hoping for high 12's but I think I am dreaming...
-Mike
Nick_Nasty's_GXP
04-10-2010, 07:01 PM
I would get rid of the cat, but it wouldn't pass NY inspection. I can't even the a hogan because it will throw a code and fail inspection! There are a lot of things I can't do because of NY.
Mgpeagle
04-10-2010, 07:03 PM
I think you can delete the P-0420 code with the Diablo. I did and still passed.... : )
-Mike
Nick_Nasty's_GXP
04-10-2010, 07:05 PM
Does it actually delete the code or just turn off the CEL?
Mgpeagle
04-10-2010, 07:07 PM
Nick,
If you are worried about appearance, I have a solution for that too. Let me know.
-Mike
Mgpeagle
04-10-2010, 07:08 PM
You can delete it through a PCM re-program. I assume the Diablo re-programs it, right?
-Mike
Nick_Nasty's_GXP
04-10-2010, 07:22 PM
Nick,
-Mike
What d'u mean?
Mgpeagle
04-10-2010, 07:39 PM
I didn't know in NY if they look under the caror not? If so, I have something you may be interested in.
-Mike
Mgpeagle
04-10-2010, 07:42 PM
I sent you a Pm...
-Mike
Nick_Nasty's_GXP
04-10-2010, 07:49 PM
-Mike
Yeah they do the whole 9 in NY :bang:
DP 08 GXP
04-10-2010, 08:17 PM
has anyone tried to move the MAP sensor on the intakes?
DavidGXP
04-10-2010, 09:34 PM
The ZO6 cam is perfect for our engines 02+ LS6
Its got a wide Lobe separation for a smooth idle with tons a of vacuum, and its got a lot more exhaust duration then the intake lobe to help with the restrictive exhaust manifolds and cat. No it's not to big. We have plenty of cam stock though. My engine with rockers will pull up to 6100.
Nick_Nasty's_GXP
04-11-2010, 05:58 PM
Thought I'd provide an update...so after a couple of days, I am hearing deeper exhaust tones, and definitely better throttle response. I had to work the last couple of days (weekends blow :bang:), but I promise I will punch it sometime this week and tell you if I notice any changes.
ImpSS07
04-11-2010, 06:07 PM
Are you on the stock tranny??
Nick_Nasty's_GXP
04-11-2010, 06:12 PM
Yeah, it's still going strong tho, so I don't plan on changing that soon (I hope)
GXP25
Any idea about a better DOD/AFM camshaft? From the L76 (G8 GT)?
neilownz
04-11-2010, 09:00 PM
I just got a bbk ssi aluminum intake pretty cheaply. Ill check the clearance issues with that. Hopefully the stock fuel rail will fit. Looks like a 5004 and I already have a truck tb to use with it.
http://www.bbkperformance.com/products/intake-manifolds/gm-manifolds/97-04-gm-ls1-and-ls6-intake-manifold.html
http://i.ebayimg.com/09/!Bp4GwCgCGk~$(KGrHqUH-EMEu1BdsSoRBLtQrM2Lmg~~_12.JPG
Mgpeagle
04-11-2010, 09:05 PM
Wow, that's nice. I hope it fits. I'd love to see the numbers.
-Mike
DavidGXP
04-11-2010, 09:32 PM
Just cut the back of your alt bracket off and get some injector adapters and that sucker will bolt right on.
neilownz
04-11-2010, 09:33 PM
I saw some professional products ones on ebay for 345$ too, but I would trust bbk more. I'm sure they are similar. Aluminum intakes do have heat soak issues, but I would rather have a bigger opening.
http://www.professional-products.com/manifoldsLS1LS2.php
http://cgi.ebay.com/ebaymotors/Professional-Products-52063-LS2-Manifold-Satin_W0QQcmdZViewItemQQhashZitem1c0f777ef4QQitemZ 120518573812QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAc cessories
http://cgi.ebay.com/ebaymotors/Professional-Products-52065-LS1-96mm-Manifold-Satin_W0QQcmdZViewItemQQhashZitem1c0f77847dQQitemZ 120518575229QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAc cessories
neilownz
04-11-2010, 09:37 PM
Yea it's a salvage take off. No idea what size those included injectors are. Hoping to just use the ls4 ones.
DavidGXP
04-11-2010, 10:27 PM
You could get away with LS6 injectors (28lb) but not LS1 26lb injectors without tuning.
You can get the injector adapters for 25.00 on E bay.
