crank angle relearn, with out break 5v wire
i have a ls1 in a rx7, i have no 5v brake signal wire. how do i do a crank angle relearn if i have no 5v signal that shows the pcm im holding the brake down?
Is this a normal issue, I thought it just took a few cranks for it to relearn. The times I started my engine after I've let the computer sit w/o power connected, cranked over a few seconds, doesn't start. Cycle ignition, starts right up every other time.
