12 bolt strange u-bolt size same as stock?
Old 04-09-2010, 10:48 PM
DNOBLE1's Avatar
Default 12 bolt strange u-bolt size same as stock?
Going to go from 10 bolt to 12 bolt Strange and already have drag bar installed (I think UMI) and do I need new u-bolts or will the same ones work? If I need new ones what and where?
Thnaks!
Donnie
Old 04-16-2010, 07:29 AM
mikey1107's Avatar
I don't know about Strange but my Moser had 3" axle tubes and required different u bolts to mount my sway bar. You will probably have to get a sway bar mount kit from UMI for the bigger tubes. I think 10 bolts have 2.5"
tubes.
Old 04-16-2010, 09:23 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
the Strange 12b axle tube will be slightly larger and will more than likely require a wider u-bolt. you could try the old muffler clamp setup like Moser has you do if you don't get a sway bar mount set installed at the factory.
Old 04-16-2010, 11:31 AM
BMR Tech's Avatar
The axle tubes of the stock rear versus the aftermarket Strange are going to be different.
You can do the muffler clamp style brackets but I am not particularly fond of them.
We do offer a weld on style bracket and a bolt on style bracket for your application. The weld on bracket would be part # SMK006 and can be found HERE
The bolt-on style brackets are not on the website but are part # SMK007.
I attached a picture of the bolt-on style brackets for you to look at.
