What kind of fuel cell is everyone using?
Im about to do my fuel system on my turbo project and i want to get an idea on what size or where i should mount it, my plan was to cut the hole where the t-tops go and welding a flat piece of metal i could fit a 13" deep x 35" wide x 15" high tank if i cut the t-top hole
street car but mostly drag, trying to get a 2800 race weight so im looking to save a lot of weight but i do want to drive it in the streets sometimes so the 12 might do, whats the stock tank ? 15gal?
If you drive it on the street you will want a reasonably big tank. At 12 gal and say 12 mpg then you have 144 mi. between fill ups. That isn't that far but should be plenty. I would think if you fill the entire area up you have available you could fit 16 plus gal. A sumped tank doesn't weigh much by it's self so you have to weigh 2-3 pounds vs. more capacity.
You have room for 47 plus gallons. There are plenty of options on summit racing 8-12and 16 gallon all easy fits in your area.
