01 6.0 and ls2 flywheel starting problem
I just stuck a 6.0 in my car as a temporary setup and had a ls2 clutch so I put that in. I am having issues starting it. First starter I tried tested good. Didn't work in the car. Second starter worked in the car for a little bit. It would wind out sometimes but still start it. It just quit on me. I pulled it apart and the internal gears are shot. Today I said screw it and bought a new one at autozone and it is just whining too. The ls2 flywheel looks like it is spaced out more than the ls1 style. I just wanted to see if anyone else has had this problem. I'm going to pull the trans tomorrow and put a different clutch but I just wanted to check first.
its a 01 and I'm 99% sure there want a spacer on it. I'm going to feel like a idiot if I find one on ther later. The strange thing is is that I did have it starting for a little while. It was winding out some but I could still get it started. Thanks for the pointers so far guys.
