LT1-LT4 Modifications - My 6AL-2 Install...
View Full Version : My 6AL-2 Install...
SoxXpupPeT
04-10-2010, 10:08 PM
I could hardly retain the excitement of opening up the box and pulling out my nice new 6al box! So much so that i installed it right away.Everyone likes to see pictures so here they are
http://img.photobucket.com/albums/v393/SoxXpupPeT/Img_7542.jpg
Thats where i decided to install it. right where the stock airbox mounts too
http://img.photobucket.com/albums/v393/SoxXpupPeT/Img_7541.jpg
custom mounting bracket
http://img.photobucket.com/albums/v393/SoxXpupPeT/Img_7545.jpg
http://img.photobucket.com/albums/v393/SoxXpupPeT/Img_7546.jpg
and installed
http://img.photobucket.com/albums/v393/SoxXpupPeT/Img_7548.jpg
If i remember correctly ive never seen anyone else mount it there before. It came out great! With it mounted like that the rev limiter and 2 step controls are right there for easy adjusting... The car feels alot more stronger! throttle response and power feel more crisp. Also not to mention the lack of raw fuel smell now from the exhaust! I havent gotten around to fuel consumption but im sure theirs a small increase with that aswell. All in all its a great box and im very happy i finally got one! and a parting gift. alittle 2 step off 3k rpm. the camera does not to it justice
http://img.photobucket.com/albums/v393/SoxXpupPeT/th_MVI_7551.jpg (http://smg.photobucket.com/albums/v393/SoxXpupPeT/?action=view&current=MVI_7551.flv)
zbomb5610
04-10-2010, 10:11 PM
nice install man, I have mine just screwed into the metal on the other side of the fuse box if you could see more toward the inside of the hood.
SoxXpupPeT
04-10-2010, 11:12 PM
thanks! I had the space there because of my custom intake setup. everyone else tends to put them where you put yours. you have to be sure to use vibrator isolators. MSD says its very important to prevent them from dealing with to much shock and vibration. aswell as to keep them away from heat.
LT1
04-10-2010, 11:27 PM
You did a good job, nice clean install!
Like said, i did mine on the opposite side under the fuse box, because im running CAI.
riceburnerZ28
04-11-2010, 12:58 AM
Clean install! You gotta love the 2 step!
flyinZ
04-11-2010, 07:55 AM
Looks good. I was looking at the same box. How did you wire everything up? 2-step also? Did you run a switch inside the car? Or wire it up to your clutch somehow?
SoxXpupPeT
04-11-2010, 08:56 AM
thanks! the 2 step function was worth the price of the box itself! well.. sort of. $250 a nice chunk of change :chug:
i used the plug and play msd wire harness (msd part # 8876) and it was a breeze. the 2 step function is a part of the 6al-2 set up. its real nice. i just have the wire plugged into the battery in the video. i havent finished hooking it up tho. i want to do a main on/off switch inside the car at least. what you said hooking it up to the clutch isnt a bad idea tho thanks!:chug:
gregrob
04-11-2010, 11:39 AM
All 6 speeds should have a 2 step.
Nice install, I've seen a few there and I'm gonna put mine there too someday. For now it sets where the Cai used to.
SoxXpupPeT
04-11-2010, 12:28 PM
agreed! just for the fun of it lol. im very happy where it is and how i mounted it. i wouldnt want it anywhere else
TheDon619
04-11-2010, 01:44 PM
i mounted my 6al in the same spot but without the mounting bracket.
suicidal racing
04-11-2010, 05:13 PM
nice,,,i always like to mount my boxs inside the car though..glove box is a good spot..i do this to keep them away from heat and moisture an stuff..
i had a coil mounted on my fire wall onces and after my engine bay would get hot the car would act up and i chased it for awhile..turned out it was getting to hot from the location..and it was clear from the header an such..just my under hood temps after a bit would do it.
gregrob
04-11-2010, 08:07 PM
Glove box is a terrible place
SoxXpupPeT
04-11-2010, 08:08 PM
I was going to attempt that but i didnt know how to do that and retain the rubber feet.
Msd says not to put it in a place where it doesnt have good ventilation. if you have the same box as me tho, they say it isnt as bad because the 6al-2 puts out less heat
suicidal racing
04-12-2010, 02:17 AM
if you think so..tell me whats worse a 150 degree engine bay or a 90 degree glove box..trust me alot of people run them in there box with the box being moded..you dont want to mount it where it cant get no air under it..
BigBadWhitey
04-12-2010, 01:09 PM
Im curious...what exactly does a two step do?
suicidal racing
04-12-2010, 02:00 PM
it gives you 2 rev limiters..the limiter for the max rpms you want to stop your engine to max rev at and then a lunch rpm..so you hit your trans brake or line lock button and its engauges the second rev limiter..say set at 4500rpms so now the max your engine will rev is 4500 rpms on the line..once you release your button for the brake or line lock it disengauges and gos back to the normal max redline rpm you have set.
gregrob
04-12-2010, 02:29 PM
Flawed logic. They specifically say NOT to put it in the glove box. Engine bay is better ventilation, and its not 150 degrees ambient...
AChotrod
04-12-2010, 02:50 PM
Looks good and gotta love the 2-step!! I put my box in the engine bay also.
http://i33.photobucket.com/albums/d53/achotrod/2step059.jpg
and did this to activate it. Didnt want it on the clutch or the shifter.
http://i33.photobucket.com/albums/d53/achotrod/2step080.jpg
SoxXpupPeT
04-12-2010, 04:50 PM
i Love your car achotrod! and thats a nice place for the 2 step button... is that a temporary on ?
LT1forever
04-13-2010, 01:22 PM
Sorry to thread hijack. But what other part s did you have to buy in order to run the 6 AL 2 properly? I've been looking into this for a while now. I'm just a total noob with as far as ignitions. Thanks!
AChotrod
04-13-2010, 01:44 PM
Thanks,
Yes its temporary for now. Not sure what Im going to do though just yet.
AChotrod
04-13-2010, 01:45 PM
The MSD plug and play harness some wire and a momentary button to activate it.
SoxXpupPeT
04-13-2010, 02:40 PM
msd part # 8876 < thats the plug and play harness for lt1's
Thanks,
really ? where are you going to finally mount it ?
AChotrod
04-13-2010, 04:47 PM
If I get someone over with wiring skills Ill have them hook it up to the radio controls on the factory wheel, or maybe get a new aftermarket wheel with a built in momentary button. Just dont like the zip ties that hold it on now.
gregrob
04-13-2010, 05:49 PM
Actually there are two part numbers for lt1s. 8876 is for the DUAL connector coil that 92-95 has (i think that's the years) 8877 is for the single connector coil used in the later years.
SoxXpupPeT
04-13-2010, 08:29 PM
lol ok i thoguth you were talking about the box itself being temporarily mounted there. im a dumbass :emb: having it on the wheel is real nice tho. i wont be able to do that without something fairly custom with my grant wheel tho...
very true i forgot to mention that. thanks for the clarification!
LT1forever
04-14-2010, 10:31 PM
So no MSD blaster coil is required with this box? Sorry for the dumb questions. I just want to be exactly sure on what I need for something I know little about.
AChotrod
04-15-2010, 10:14 AM
I run a stock coil.
AChotrod
04-15-2010, 10:15 AM
The box stays where its at. Drill a hole in the grant wheel for a momentary button.
collier341
04-15-2010, 11:43 AM
Sweet install man. It fits perfect there. How come it's upside down though??
EDIT: I see the controlls on the bottom now. My bad.
SoxXpupPeT
04-15-2010, 05:16 PM
i dont think you would need one. but it couldnt hurt. if you have one already tho its fine.
i would if my wheel was a POS but its just to pretty hahah ill figure it out one day. i have to much other stuff going on to worry about that as of yet. but thanks!
Thanks! the 6AL-2 is alittle bit smaller then the old 6AL and when i saw that spot i figured itd be perfect for it. and sure enough it was lol
AChotrod
04-15-2010, 06:00 PM
Do something like this. It will look sweet!
http://www.burkhartchassis.com/id86.html
SoxXpupPeT
04-15-2010, 10:42 PM
that would look really sharp and would be the perfect spot but unfortunately my grant wheel doesnt have any holes in it :( lol
LT1forever
04-16-2010, 09:22 PM
[QUOTE=SoxXpupPeT;13193164]i dont think you would need one. but it couldnt hurt. if you have one already tho its fine.
Are you running the 6 AL 2 box by itself?
SoxXpupPeT
04-16-2010, 11:17 PM
^^ the box is just an add-on to the already functioning ignition setup
MattSapp95_T/A
04-17-2010, 01:32 AM
I have that same wheel in my 95 Trans Am and I have my momentary button in the same hole...works really well and looks good!
I Very nice install on the MSD box!!
Matt
