HPT: bigger TB and Intake ???
Hi just wondering if i change from 78mm TB to 90mm TB do i need to make some changes in the HPT other then Maf and VE tables???
And also if i change for bigger more flowing intake are there other changes to make other then MAF and VE
thanks
Baezi
thanks
Baezi
A TB alone does stuff all (very overated mod). But in saying that it will effect your IAC so rescaling your desired airflow is not a bad idea (even though the trims should sort it).
Changing intake has the potential to increase VE. Subsequently timing should be retarded to optimise for it.
