dei 530t with autotrix pass window mod
Ok so I have done the autotrix pass side window mod and that works great , but recently I have added a Dei 530t express up down module. From reading other posts about this subject it seems that the relays need to be wired between the switch and the dei module. Well i wired it that way but for some reason with key on and pass window switch pressed the fuse for the relays instantly blows. The way that i wired it is as follows pin 85 has brown/black wire , pin 85 on other relay has white/black wire , pin 30 green/black wire to motor, pin 30 blue/black wire to motor, the above wires are from the dei module. If i disconnect the dei module from the relays the windows works fine. Maybe I am just not quite understanding the wiring, but any help would greatly be appreciated.
