Tuning for E10
Tuning for E10
I have a 2001 z06 SD tuned w/ efilive.... I do all my own tuning....
ok here goes.....
Should I set the stoich at 14.63(GAS) or 14.12(E10) THESE ARE THE STOICH VALUES THAT I USE...
Does the E10 make a difference in fueling @ WOT? Any gas w/ ethanol should technicaly be richer depending on how much ethanol is added
Now up here in the northeast all the pumps use E10.... so what u think? remember Im sd tuned, so no maf for corrections....
thanks
ok here goes.....
thanks
It can be set to anything you want but you'll need to make a new calc_pid to convert voltage to AFR based on {B3601}.
How to match wideband output to {B3601}
