Pontiac GTO 2004-2006 - Buyin some mickey thompson et streets..
MiamiFan4Sho
04-13-2010, 11:46 AM
how much time do you think goin from street tires to drag radials should shed in in the 1/8th mile? ive ran a 8.02 when i hooked really good on street tires before in my A4 LS2, cut a 1.90 60', wonder how much ill shed on the 60', any ideas?
05JUDGE
04-13-2010, 02:15 PM
M/T drag radials should get you a 1.6-1.7 60ft easy.
MiamiFan4Sho
04-13-2010, 02:31 PM
well the guy im buying them from said he pulled a 1.6 with em on a 150 shot...but im sure my A4 will benefit with em
05JUDGE
04-13-2010, 03:50 PM
I am an A4 and my best 60ft so far is 1.58. You will definately benefit from them.
MiamiFan4Sho
04-13-2010, 04:34 PM
i hope so! i will find out friday night! gettijn tires and drag bags so im hoping for a 7.7X
05JUDGE
04-13-2010, 04:42 PM
The one thing I did that really helped me was taking my tire pressure down to about 14psi. It's amazing how high the psi goes after a burnout and run down the track. I was finding my tires at almost 22psi after a run.
MiamiFan4Sho
04-13-2010, 06:39 PM
i should really take em that low? i figured 18 or 19, but ill give it a try.
05JUDGE
04-13-2010, 07:42 PM
Basically what I did was start at 20psi and work my way down. You certainly don't have to take them that low, but that's where they hooked best for me. I made several runs the same night and 14psi netted me the best 60ft. Hopefully others will chime in and give you some other tips on where to start. I can't say my methods are all correct, they just work for me.
MiamiFan4Sho
04-13-2010, 07:54 PM
gotcha well this is my first time with drag radials, ive always had street tires and ran em around 22 psi...
MiamiFan4Sho
btw what kinda times do you run?
05JUDGE
04-13-2010, 08:03 PM
If you look in my signature, click on the "first 1/4 mile with 427". That was my best run at 11.52 @ 117mph with a 1.58 60ft. That was the run I dropped to 14psi. I don't have that motor anymore but I should be running about the same times.
MiamiFan4Sho
04-13-2010, 08:15 PM
not to shabby...the nearest 1/4 mile is 150 miles away...think it would be a neat expirience!
nick.celis
04-13-2010, 08:28 PM
those tires are awesome, make sure to do a decent burnout though. and good luck on your runs! let us know your new times
MiamiFan4Sho
04-13-2010, 08:34 PM
ya for sure, no point in buying them if you dont heat them up right? im going this friday so it should be interesting, any guesses? ran a PB of 8.02@89.6 with a 1.9 60', never have hit a 60' that low, usually 2.0Xs, and 8.1Xs..
nick.celis
04-13-2010, 08:55 PM
Hmm, is guess youll run 7.8x best and 7.9x all day. U should be able to pull off a 1.7 60ft. with brand new MT E/T radials, i got a 1.7 60ft with a shitty ass burnout. Given your times though, with a decent burn out your gonna dead hook!
MiamiFan4Sho
04-13-2010, 09:07 PM
hopefully your wrong lol i took a few punds out the car as well, the little metal brace under the spare tire well, because i had to drill hole for my nitrous bottle, the brace around the gas tank..i need a stall converter, those wake up the a4s big time from what ive seen
MiamiFan4Sho
04-15-2010, 11:11 PM
got my drag bags installed tonight! and got my tires as well, will post up the new number tomorrow night!
05JUDGE
04-16-2010, 08:46 AM
Good Luck! Anxious to see how these work for you.
CanadianGoat
04-16-2010, 01:30 PM
1.9x's are decent for a street tire--Im guessing you werent spinning that much on that launch. With your level of mods I dont see you getting much lower than 1.8x's. If you are still running the stock convertor you are limited to how hard it will hit off the line with an A4.
