New brakes
New brakes
hey im lookin into new rotors, pads etc..... i was looking at these
http://www.stranoparts.com/partdetai...=191&ModelID=7
Has, or is anybody using these? what do u guys think? some feedback would be great. thanks!
Haven't had the chance to use Ate's on my Camaro, but I have had a similar combo and it's actually quite sufficient.
EDIT: have had Ate's on other vehicles and they're very well made without being boat anchors.
LS1TECH Sponsor
Second, nicer rotors for the money? I have to disagree with that. ATE's are fully coated (not sprayed with a wash, but coated like a powdercoat) to prevent corrosion. They meet all OEM specs, and are made by a world renown company in brakes. ATE is an OEM supplier to VW, Audi, BMW, Porsche to name a few.
Third, the slotting design is superior to many others for two reasons. 1. It's shallow, taking the minimum structure away from the rotor and acting also as wear indicators. When the slots are gone, the rotors need replaced. 2. The pattern of the slots leaves no sharp points to act as stress risers. And you'll note the slot does not run to the very edge of the rotor for the same reason.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Necessary? No. Not a bad idea with the car being 11 years old, but not necessary.
__________________
