New Products Showcase Come inside to see the newest hardware!
Helion 2010 Camaro twin turbo kit makes 580rwhp
Old 04-15-2010, 10:36 AM
Nasty N8's Avatar
Default Helion 2010 Camaro twin turbo kit makes 580rwhp
The highly anticipated Hellion Twin Turbo system for the 2010-2012 SS Camaro Made 580rwhp just as the kit is sold and is now available!
Hellion has developed the ultimate system to take the high performance SS to the next level
This bolt on-complete system has everything expected in a high performance twin turbo setup. The twin 58mm Turbonetics turbos feed a safe 6 lbs of boost and produce an amazing 680 hp! This is all possible without the need for aftermarket headers or exhaust. This system is engineered for a perfect fit and an OEM appearance. With a capability of over 1,000 hp, it will be the only performance add-on you need to buy. Keep your revolutionary SS Camaro in front.
2010-2012 Camaro SS Twin Turbo System - 500 - 1,000+ HP with Tuner & Injectors - $7,695.00
System includes:
-Twin 58mm Turbonetics wastegates (61mm optional)
-All stainless steel construction (lifetime warranty)
-Twin Turbosmart wastegates
-Turbosmart blow off valve
-Handheld tuner with program
-52 lb injectors
System Options
Ball Bearing Option (Both Turbos)
$800
Upgrade to 61mm Turbos $790
AEM Wide Band O2 Sensor and Gauge $205
TurboSmart eBoost2 Boost Controller
$486
Extra Solenoid (Use with eBoost for Twin Turbo Applications)
$90
Any more info on this and more please give us a call
Attached Thumbnails Helion 2010 Camaro twin turbo kit makes 580rwhp-2010-camaro-turbo.jpg
Quick Reply: Helion 2010 Camaro twin turbo kit makes 580rwhp
