Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
'05 high oil temp
Old 04-15-2010, 10:44 AM
pcf_mark's Avatar
Default '05 high oil temp
The dealer has had my car 5 days to solve high oil temp warning I am getting from dash digital gauge. 300 degree+, cools to 280, climbs to 300 etc. They did not even know the car was equipped with an oil temp sensor and argued with me when I told them it MUST have one for the instrument to work! They are replacing the level/temp sensor on the side of the pan. Anyone experience this?
They have never checked to see if the oil was ACTUALLY hot so I guess I am going to find a new dealer.
Old 04-15-2010, 11:37 AM
Goats's Avatar
I did. The oil temp/pressure sensor was bad. I can give you more details later but the problem is noted in the service bulletins for the 04-05 CTS-V. My problem was with the oil pressure not the temp.
Old 04-15-2010, 12:30 PM
SoCA04V's Avatar
I have had the same problem. Dealer had it for a week and replaced the temp sensor....problem is still there.
Old 04-15-2010, 06:11 PM
DoctorNick's Avatar
Water pump going bad? Whats the coolant running at?
Old 04-15-2010, 07:43 PM
-T-
-T-'s Avatar
I had the same thing. I think I titled the thread "oil temps 290+". I only had the problems on hot days in traffic. Verdict I beleive was a ground resistance difference at the display. I even think someone had the problem at the track and carried an IR gun and found temps to actually he around 220 rather than 300+
Old 04-15-2010, 08:34 PM
SoCA04V's Avatar
Ya, I don't think the temp is actually over 300, I think the display is incorrect. My water temp runs normal, so it's hard to believe oil temp would be off the charts.
Old 04-16-2010, 12:01 AM
A-Bomb's Avatar
i read somewhere that is was a grounding issue. get a volt meter and see which wire is the - negative and ground it and see what happens. i'd try a jumper wire first before i cut/splice the wire.
Old 04-16-2010, 10:39 AM
pcf_mark's Avatar
Looks like a new sensor did the trick. I sat in traffic today and it stayed in the same range as coolant like it has been for years. 200-210
Thanks
Quick Reply: '05 high oil temp
