Bad u-joint....?
Bad u-joint....?
My SS has a thumping noise only when moving, I wonder if its the u-joints. I have a stock driveshaft and a Moser 12 bolt with a 1350 yoke. How do you check the u-joints?
Certainly could be. Easiest way to check the rear one is to get under the car and try moving the drive shaft up and down. If you have a greaseable u joint grease it some. If it moves much its time to replace it.
