Anyone have a wiring diagram?
Old 04-16-2010, 04:45 PM
Slo-Maro_Uncorked's Avatar
Default Anyone have a wiring diagram?
Wanting to eliminate the in-car harness... Everything in the car is switched
and relayed to external pumps/fans. Basically an all-out race car running through a '99 PCM w/ HPT. I want to get rid of all of the wiring I don't need
anymore to clean things up; looking for a wiring diagram to make sure all of my I's are dotted before I rip everything out. Anybody have one?
Old 04-16-2010, 05:14 PM
vteckiller's Avatar
i was on mitchell on demand looking for you. theres 4 pages of power ditribution diagrams and 4 pages of ground ditribution diagrams and many others for more specific things. could you be more specific of the diagram you want or i can just post up those 4 pages power distribution pages.
Old 04-17-2010, 09:49 AM
Dude, I appreciate it. If you can post what you found, that would be killer.
I'm pretty much looking for all BCM-related wiring, as the PCM is already
set up correctly. Thanks again!
Old 04-17-2010, 07:42 PM
vteckiller's Avatar
I think this is what you are looking for. i had to do it in 3 pictures so you could actually read the small letters
Old 04-18-2010, 10:05 AM
That's a big help to get started. Thanks a ton. I knew
that 95% of the wiring wasn't needed, but figuring out
the 2 or 3 wires I'll need to jumper or direct line is
the hurdle. This will get me most of the way there.
Old 04-18-2010, 10:07 AM
After I get this done, it's back to the dyno. I want to see 1000whp
with a strong and clean power curve. Pulling any power drains from
the system won't hurt...
Old 04-18-2010, 11:38 AM
vteckiller's Avatar
Post up a dyno video!!
Old 04-19-2010, 06:50 AM
Pocket's Avatar
Either buy or rework your existing engine harness to a stand alone unit so it runs with a single 12v switched input. The dash and rear harness should be replaced with a classic hotrod harness. Just enough to run the essentials and nothing else
You will be pulling your hair out trimming the stock dash harness down
Old 04-19-2010, 04:37 PM
The engine harness & PCM is going to be replaced by BS3 or Motec
before Bonneville next year, but I want to get what I can out of the
way for now. I'm not screwing around with anything forward of the
firewall; mainly hard-wiring all the 12v stuff... Just needed to know
which wires those were.
Quick Reply: Anyone have a wiring diagram?
