lh8 pan on third gen ls1 swap
has anyone used an lh8 pan for their swap? if so how was k-member clearance. also any ground clearance issues? ls1 is going in a 88 camaro
Do a search on TGO about it. Its 2" lower than the Fbody pan which is dead flush with the bottom of the K-member, so ground clearance is an issue. Truck pans are more compact so clearance around the K-member should be excellent
The Fbody pan will fit the best. 2nd best is the LS2 corvette pan, but those are hard to come by
