Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
How do you delete passenger wiper only?
Old 04-18-2010, 05:53 PM
1aDRAG's Avatar
Default How do you delete passenger wiper only?
I have a 93 Camaro with a SBC. The carb sit up very high. It has a super victor intake with a 2" carb spacer. The float level adjuster is about .150" from hitting the windshield. I had to cut the passenger wiper completely off. I want the driver wiper to be functional but I don't see any easy way to do this. The wiper motor is on the driver side then has a rod that run to the passenger wiper then a rod that run back to the driver side wiper. Has anyone done this mod before?
Old 04-18-2010, 07:44 PM
In-Zane Moderator
ZONES89RS's Avatar
As far as i know, you are screwed unless you can make something else work,(custom).
Old 04-19-2010, 12:38 AM
Vortec355's Avatar
I have the same problem, but I just run no wipers for now. I guess the only way to run wipers would be to relocate the passenger wiper towards the driverside 6 inches and shorten the rods.
Quick Reply: How do you delete passenger wiper only?
