Florida Members Fun, sun and LS1's
any alignment expert here?
Old 04-19-2010, 10:39 AM
toplessHO's Avatar
Default any alignment expert here?
Ive got some questions about a Hunter
thanks
Old 04-19-2010, 11:46 AM
LS1Tech Sponsor
performabuilt2's Avatar
give me a call 352-729-3199
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old 04-19-2010, 11:57 AM
mrr23's Avatar
i've owned hunter alignment machines for the last 10 years. and i do nothing but alignments and suspension work. whatcha need?
Old 04-19-2010, 02:22 PM
PSJ
PSJ's Avatar
Hello Robert,
I heard you moved and were not set up.
Are you now set up and working?
PM me your number and address.
Old 04-19-2010, 02:34 PM
mrr23's Avatar
yep i finally got a car rack installed last week.
Old 04-19-2010, 08:03 PM
kwiksilverz28's Avatar
Thank god. I need tires this year on the av. lol
Old 04-20-2010, 07:06 AM
toplessHO's Avatar
sent PM
got it working late last night/early AM
mainly curious as to the readings I got on the rear.
Im going to switch the toe heads to front today and see what this comes up with.
02 TA stock 245-50x16
rear:
camber left 0.5 right -0.2
cross camber 0.7
toe left -1.41 right 1.38
total toe -0.02
setback 0.10
thrust angle 1.42
front
camber left -0.2 right -0.6
toe left -1.98 right 0.85
total toe -1.13
Old 04-21-2010, 12:09 PM
mrr23's Avatar
good thing we have a tire machine as well
Old 04-21-2010, 12:14 PM
mrr23's Avatar
Originally Posted by toplessHO
sent PM
rear:
cross camber 0.7
total toe -0.02
setback 0.10
thrust angle 1.42
front
total toe -1.13
it looks like the machine is out of calibration. the thrust angle of 1.42* is like saying the rear axle turned to the right about 3/4". when you bring the car to my shop we'll verify that. then again you have the heads reversed and the rear heads on the front showing the tow not equal might be throwing the thrust angle number off. i do have cal fixture that i use to keep mine calibrated. is your G111 all electronic or do you have to string front to back connecting the sensors?
Old 04-21-2010, 02:36 PM
toplessHO's Avatar
all electronic with optical front to rear
update to 04 specs
redid with the heads in right position
had to reset camber on front,right was
a little more than left.
I have the specs you posted(I think On GTO LS1 forum)
but maybe Im reading wrong because you show alot more camber than factory specs.
I set camber as close to zero as I could get.My buddy sets his auto cross cars up for a lot of neg camber.
Old 04-21-2010, 08:02 PM
mrr23's Avatar
the factory specs call for postive camber.
95-02 except 95-96 w/Goodyear Eagle RSA tire
camber 0.40* +/- 0.50*
caster 4.80* +/- 0.50*
total toe 0.00* +/- 0.20*
not necessarily good for outside tire wear.
Old 04-21-2010, 08:25 PM
toplessHO's Avatar
good to know
I guess Im being too critical here
Old 04-22-2010, 08:19 PM
JimMueller's Avatar
Hijacked... that's great news! I finally removed those tires that were 'bald' last October about 3 weeks ago. Wires were sticking up from the inside edge on the rear as well as the rubber was starting to separate.
Old 04-23-2010, 06:53 AM
toplessHO's Avatar
FYI Robert fixed me right up,showed me what was off on my machine.2 thumbs up!Anyone have any wheel racks?
Old 04-23-2010, 09:01 AM
mrr23's Avatar
glad i could help out
Old 04-23-2010, 11:48 AM
toplessHO's Avatar
Now I just need to find some good tall alignment wheel stands.
If you know of any LMK
Old 04-23-2010, 07:04 PM
Oh shoot. I was hoping for a reliable alignment. Woohoo!
Old 04-24-2010, 10:06 PM
mrr23's Avatar
i'll see what i can do there as well.
Old 04-25-2010, 02:27 AM
Bluechevyz28's Avatar
any chance this might mean doing car alignments again?
Old 04-26-2010, 11:51 AM
mrr23's Avatar
very much so. put a car lift in about two weeks ago.
Quick Reply: any alignment expert here?
