Is the ls1 camaro a pressurized coolant system?
I need to know whether the ls1 is a pressurized coolant system or not? Also the tube that feeds coolant from the throttle body to the radiator, can I just plug that up?
1 Post
search "throttle body bypass" and you'll get all the info you need for that portion...
I myself eliminated the throttle body coolant line, smoothed it out and then had it powder coated so you'll never know it was there
