1-2 T56 billet key springs
Old 04-20-2010, 01:42 AM
jmd
jmd's Avatar
Post 1-2 T56 billet key springs
Anyone have the springs for billet keys for a stock F-body synchro?
Flat or round wire? What do the ends look like and what's the distance between ends?
I have some billet keys but not sure if I have the right springs.
thanks
Old 04-20-2010, 06:20 AM
85MikeTPI's Avatar
Round wire. The ones from TGB are green. Curled out from the ends. When installed, they just clear the key edges.
Old 04-20-2010, 08:10 AM
jmd
jmd's Avatar
Thx Mike.
Old 04-30-2010, 09:44 PM
jmd
jmd's Avatar
Who has modded the C5 billet 1-2 keys to work in the F-body 1-2 synchro?
I ground the 2 bumps (and a tiny bit more) off the inside hub-side face of each key. Nothing else.
Assembling an F-body box; no 1-2.
Does anything need done to the slider side bump?
How about at the slider side shoulders? That seems the biggest different from the general shape of a stock stamped F-body 1-2 key.
Old 04-30-2010, 11:51 PM
1madss's Avatar
85MikeTPI - Have you used these springs before? I finally upgraded to the billet keys this time around and used the same kit you had above. It seemed the the springs were a little long and did not sit firmly against the middle key. It may not be a problem when the blocker rings are installed. Just wondering.
TIA
Old 05-01-2010, 08:07 AM
85MikeTPI's Avatar
I've used them.. Ground down the 2 end lips that engage the blocker rings.
I didn't have to touch the centering bump. Everything was test fit before assembly.
Old 05-01-2010, 08:10 AM
85MikeTPI's Avatar
TIA
Yup, dozens of times.
Old 05-18-2010, 03:29 PM
9t8z28's Avatar
I just got the billet keys and springs. The spring ends (hooks) do not sit like yours do in this pic. Mine are longer, therefor the one end hooks onto the billet key and the other end (hook) falls in between the other 2 keys. Is this correct?
Also, are the springs supposed to be installed as a mirror image or should they be staggered?
Old 05-18-2010, 05:50 PM
85MikeTPI's Avatar
Do your billet keys have a hole drilled in them to hook the spring into? If not, the spring should overlap the keys like shown.
You should stagger the springs on both sides of the synchro, so the spring gaps should not be between the same two keys.
Old 05-18-2010, 07:00 PM
9t8z28's Avatar
No hole drilled in them but my spring does not hook onto 2 of the billet keys like shown in the pic. It only hooks onto 1 of them and it overlaps the other two keys. The billet keys and green springs look exactly like the ones pictured but my springs seems to be
Old 05-18-2010, 09:54 PM
9t8z28's Avatar
Nevermind, I was wrong. It is the same. Sorry.
Quick Reply: 1-2 T56 billet key springs
