rebuild problems.....
Old 04-20-2010, 02:12 AM
suede's Avatar
Default rebuild problems.....
So i just went through a 8 month fiasco getting warrantee to cover reverse that went out on the trans am, (00 ws6 6spd) and just got it back this weekend, and am a little irate with them, to go into reverse it takes "i am all that is man" strength to get it shoved over to where it can go up into reverse... reverse works, and will stay engaged just fine, but my mom could not get it pushed over... it goes left for 1 and 2 just fine, 3 and 4 just like butter, and 5/6 no problem but to go the extra left over to reverse takes alot of pressure, theres no pop over as if you were say overpowering a reverse lockout, just takes that much extra to get it shoved over, and it was never like that....
so my question is what did they screw up now?
Old 04-20-2010, 02:42 AM
jmd
jmd's Avatar
wiring plug to the reverse lockout solenoid might not be hooked up.
Old 04-20-2010, 02:44 AM
9Green-Z8's Avatar
will they charge you if you take it back who did the work?
Old 04-20-2010, 02:48 AM
suede's Avatar
where is the plug, and wouldnt that make it not let it go in at all?
if they charge me after the fiasco i went through in the first place ill flip....
Old 04-20-2010, 06:53 AM
MUSTANGBRKR02's Avatar
Definetly check the connector but also trace the wires up to see if they are burnt on the exhaust.
Old 04-20-2010, 08:13 AM
jmd
jmd's Avatar
Post
under the car. drivers side of trans. Left of shifter.
Nope; you described how it works. Strength required to push through when unpowered.
I'd be worse than you are gonna be.
Old 04-20-2010, 04:26 PM
suede's Avatar
alright, ill check on that, thanks for the suggestion, and yea not been happy, after dropping 6k on paint wheels, and few other things and it sits outside uncovered for 8 months
Old 04-23-2010, 03:42 PM
9Green-Z8's Avatar
is your problem fixed?
