GTO Trans in Fbody?
GTO Trans in Fbody?
Anyone know the difference? I have an oppurtunity to get one cheap and I heard there were improvements for the GTO trans. Ratios different?
Anybody know if they are improved and what it takes to drop one in an fbody?
Thanks
Chris
Thanks
Chris
The MM6/M12 specs are here
http://www.cadillacfaq.com/faq/answers/pdf/t56-06.pdf
Yeah its an upgrade, but unless your T56 needs an overhaul I probably wouldn't go though the effort, but if your getting a smoking deal it might be worth it. Don rebuilt many a T56 as well, just an FYI.
The M12 is arguably the best t56 you can get. Here are the ratios btw
Your T56 2.66:1 1.78:1 1.30:1 1.00:1 0.74:1 0.50:1
GTO M12 2.97:1 2.07:1 1.43:1 1.00:1 0.84:1 0.57:1
Great info Dan. Thanks.
Keep the feedback coming. I am considering this swap. A GTO just came in and I was given dibs on the trans. All years the same?
If your getting a good deal it would be worth picking up. One in great shape is probably worth a good $1500 to a guy looking for a tranny.
i had it in my ta for 2 years w/ 4.10s i loved it but needed something alittle more beefier.
w/ 26" tires i would run through the gears fast and shift into 4th a tick before the 1/8 and 4th would take me through the traps at 6800 so nice!!
yes you will need the little shifter cup thing from a fbody, i have nothing bad to say about the mn12 in a fbody
-brandon
-brandon
Just went the other way and put a faceplated t56 from an f body into my gto. All i swapped were the shifter cups. The car gets better gas mileage now, in 6th at 80 i am at like 1700 rpm's, i need to add some gear!
