Rear End Noise , Wheel bearing?
Old 04-20-2010, 10:23 AM
gfeller2006's Avatar
Default Rear End Noise , Wheel bearing?
Ok so I have developed this pulsating whoom whoom whoom noise, or kind of a whirr whirr whirr noise from the rear. Also a friend had my car on a lift and put it in gear to listen and though the tire was wobbling a little bit like the axle may be bent. Does this sound like a bent axle/ wheel bearing problem to you guys?
Old 04-20-2010, 10:25 AM
Tx91z28's Avatar
sounds just like when my axle was bent
Old 04-20-2010, 10:27 AM
Kevin01Z28's Avatar
Probably, or a bent wheel who knows. If you want to check the wheel put it on the front and spin it. Pull the axle and roll it to see if its bent and check the bearing surface. Axle bearings are cheap and easy to install.
Old 04-20-2010, 10:34 AM
I actually did put the wheel on a wheel balancer and it spun true. It only wobbles when hooked on the car.
Old 04-21-2010, 08:54 AM
bump bump
Old 04-21-2010, 08:08 PM
SMS
SMS's Avatar
When you are driving, does the sound change if you steer left and right? If so it may be a wheel bearing. I had a sound similar to yours but the sound didn't change when I steered left and right. Turned out to be a wiped out carrier bearing.
Quick Reply: Rear End Noise , Wheel bearing?
