Header install check list
Old 04-20-2010, 11:21 AM
yarmish's Avatar
Default Header install check list
I am going to be ordering everything i need and wanted to be sure i have everything. I have searched and read the stickys but want everything correct.
1- pacesetter longtubes
2- tsp catted y
3- o2 extensions
4- plugs,not sure which ngk's i need. stock ls1
5-need to send my computer in for a mail order tune. get the rear 02's knocked out
6-motor mounts - where is a good place to purchase these? Looks like a major PITA but is worth it
also a good step by step write up would be good but havent found one yet.
thanks in adavance
Old 04-20-2010, 12:12 PM
1BAD_LS1 Tunes's Avatar
Look me up when you get ready for a tune, well get you setup!
Blaine
Old 04-20-2010, 12:15 PM
Lambert695's Avatar
List looks good. tr-55 are the plugs you would want. stock heat range and all that stuff.
Here is a site for the motormounts if you would like.
http://www.ws6project.com/user_stor/...oducts_id=1490
there are a couple write ups out there just google it.
good luck!
Old 04-20-2010, 12:59 PM
yarmish's Avatar
Blaine
Will do..what is the turn around time for this? I may just get it done now so i can drive the car right after i get everything installed
Old 04-20-2010, 01:00 PM
yarmish's Avatar
good luck!
Thanks alot..will be ordering them up
Old 04-20-2010, 01:24 PM
sjsingle1's Avatar
poly MM.......good deal..........GM header gaskets 2
Old 04-20-2010, 01:30 PM
TooLateVTEC's Avatar
I see a bottle of Jack Daniels missing from the list.
A 1/4" air rathet is the **** here, as well as a ratcheting 10mm wrench.
Old 04-20-2010, 02:15 PM
yarmish's Avatar
ok so header gaskets..definitely a bottle of daniels
i have a 3/8" air ratchet but 1/4" is needed?
a ratcheting 10mm box end wrench?
thanks alot for all this great info
Old 04-20-2010, 02:28 PM
Lambert695's Avatar
yeah like a tiny 10mm ratchet wrench... it is your best friend for the passenger side header bolts. There is NO room back there what so ever. A friend is also recommended. It helps to have an extra hand if needed.
Old 04-20-2010, 03:53 PM
00T/AWS6's Avatar
As was said might as well replace the head gaskets if they are stock. I'd clean the header bolts off real good or buy some new ones. A lot of mine got fussy haha. 10 mm ratchet wrench is a freaken savior, i couldn't do without one.
Old 04-20-2010, 05:10 PM
Pcms are normally sent out the morning after I receive it.. and normally takes 2-4 days for you to receive it after its sent!
If you have anymore questions don't be afraid to ask!
Blaine
Old 04-20-2010, 05:26 PM
yarmish's Avatar
Ok so i will bait a few friends over to have a couple tall boys and make thim work.. ok i will check out my local sears tommorow to see if i can find a 10 mm ratchet wrench
The parts store in my area carries factory type exhaust manifold gaskets "fel-pro" would these be adequate or should i source from a gm dealership?
Blaine
Thanks alot! I will probably fill the form out and said it out early next week,is the car ok to drive after even if the headers arent installed yet or is it better to wait untill after the install?
again thanks alot guys!
Old 04-20-2010, 06:08 PM
Lambert695's Avatar
I think I went with some GM ones and they work great. You can just order them from the same site as those motor mounts. Let us know how the tune goes... I was gonna wait to get a tune after I throw heads and a cam in it but for 50 bucks I just might have to try it out!
