weld it over or remove old weld and clamp?
Old 04-20-2010, 12:50 PM
senicalj4579's Avatar
Default weld it over or remove old weld and clamp?
i had a shop weld my cb pipe to ory merge. its the worst weld iv ever seen and it leaks. i wish i would have just kept the clamp on it. what should i do weld over it or remove the welds and clamp? if i did remove the weld how can i do this?
Old 04-20-2010, 01:09 PM
sjsingle1's Avatar
you can grind the welds...or....have them arc gouged.....welder here
Old 04-20-2010, 01:14 PM
the pipe is under the car installed. it would be a bitch to get in there and grind specially with no lift. could it just be welded over the existing weld? this is bs you should see this weld.
Old 04-20-2010, 01:16 PM
sjsingle1's Avatar
a crappy weld should be removed..........no 2 ways about it
Old 04-20-2010, 01:29 PM
thanks bud
Old 04-20-2010, 01:52 PM
VeTTeMaNC486's Avatar
Should post pics of this weld.
Old 04-20-2010, 02:14 PM
Old 04-20-2010, 02:17 PM
wow. Gross. Looks like someones first time attempting to weld.
You say this was a shop? LOL.
Old 04-20-2010, 02:19 PM
i stuck some quick steel up on top where its leakin the most for now until i take the ******* thing apart.
Old 04-20-2010, 02:20 PM
Trunion King
bene's Avatar
Wow, was he a newb? I say, cut that section out put a new pipe however pay someone else to do your welding.
yep a shop down the road. this header install turned into a huge nightmare.
Old 04-20-2010, 02:27 PM
01ssreda4's Avatar
did they try to stick weld this or was this wire gun. Either way it looks shitty.
Old 04-20-2010, 02:35 PM
im not sure what they used but there was some slag stickin up on top that jabed my finger pretty good. bastards
Old 04-20-2010, 05:28 PM
99LSS1's Avatar
First of all, You should NEVER weld your exhaust!!! If you have ever tried to remove a Transmission with a welded exhaust you would know what I am talking about. You should always use the clamps that come with the system you are installing... Amazing how Exhaust shops who do no other mechanical work so easily will weld up an exhaust system!!!
Old 04-20-2010, 05:31 PM
99LSS1's Avatar
Sorry about the Rant!! In answer to your question. You should at least grind off the old weld. You now may have no other option than to re-weld it.
Old 04-20-2010, 05:32 PM
technical's Avatar
Looks like someone melted some metal and sprayed it on the pipe. That's one fabu' booger bead.
With respect to the question at hand.... it's nothing a grinder and an actual welder couldn't easily fix.
Old 04-20-2010, 06:05 PM
tom falco's Avatar
Those welds need to be removed and ground clean and rewelded. Looks like he either ran out of gas on his wire feed or just does not nave good welding skills. My mother welds better than that and she is 87. Pop was a great welder and i am pritty good and sometimes mess up.Everyone does at times. But those welds are BAD REAL BAD.
