What gears for supercharged Trans Am?
Its about time to pull the trigger on an S60 but I'm still confused on gear choice for M6 street/strip car.
Car is right around stock weight (3500 without driver) after some weight reduction. Will have a little bit more here soon on the street and even more for the strip. Making 518 RWTQ with similar HP at lower RPM's. Shifting around 6200-6400 RPM's also.
The car is in the most recent GMHTP if you've seen it.
I'm looking to run a 26" tire, but can go up maybe another inch if I have to on the track.
I've heard I may run out of 4th gear with 4.10's which I definitely don't want.
What about 3.90's?
What's the best way to select gears for an FI car? I'm hoping to only do this once.
What about 3.90's?
i would guess 342 gear would be perfect for a FI car. especially if you are wanting or perfer to run a 26 inch tire and your top-end should be pretty high ,like 130 + mph . you can still go up to a 27 inch hoosier if you want and you should be ok...i guess.
