heater core need to be aluminum?
Hello,
Doing a LS conversion on a 65 Impala.
Does the heater core also need to be aluminum? I am thinking answer is yes since it will galvanically corrode like the radiator would.
Any input appreciated.
Personally, I don't see why you would need the same for both parts; rad and heater core. I've heard a couple schools of thought to this, but I wouldn't worry about material differences. You can get a sacrificial anode for the rad from a couple places to take the worry about the coolant eating anything anytime soon.
alot of late model ones are aluminum. but if your really worried about it, you could use some coolant conditioner. its in a white bottle shaped like an antifreeze jug, i think the brand is zerex. its supposed to lubricate all the cooling system components (seals in the pump i guess) and keep anything from eating or depositing in the system.
I just figured since there is a big deal about using aluminum for the radiator, why would you not use it for the heater core since it is part of the same system.
Anyone think I should just use a 4 core brass with an anode in the system? How long do the anodes last?
sawzall wielding director
I wasn`t even aware there would be problems with running a brass radiator.....I had one when I first completed the swap. I did change to an aluminum one later, but that was because I punctured the brass one during the swap and didn`t trust my solder job for too long. Been running the brass heater core for the past 5 years and 60k without any problems.
I run the prestone extended life coolant, no problems other than that stuff is nasty oilyish yuck. But it doesn`t seem like any of the stores in my area stock the good old green stuff so I guess I`m stuck with it.
the only way the aluminum will "galvanically corrode" with other dissimilar metals is if they are in direct electrical contact. That is why rubber isolators are needed to mount an aluminum radiator. Not an issue with the heater core. Unless you are using copper heater hoses I guess.
Simply don't worry about it.
They have been making cars with iron blocks, brass radiators and aluminum heads-water pumps-intakes since the 60's or earlier. You can't run straight water, you have to have some type of antifreeze, but that is standard.
Thanks for the info. I read a couple books and they had me worried about the problems.
Since the two brass ones that I have are of unknown condition, I guess I will send them to a shop to get looked at.
