Convertible Vehicles - Roof replace
YORK_MUSTAINE
04-21-2010, 08:53 PM
some body have seen a instructions or how to,, for a replace a roof in a convertible camaro ss?
i got a new roof and its not so easy replace, im trying 2 days
Stuinkuwait
04-24-2010, 10:42 AM
I have seen a top supplier on ebay that has a DVD install video 4 sale. I was going to get it just to see how hard it is to replace.
YORK_MUSTAINE
04-26-2010, 11:36 AM
THANKS SO MUCH
I FOUND IT
http://cgi.ebay.com/ebaymotors/Camaro-98-99-00-01-02-Convertible-Top-Installation-DVD-_W0QQcmdZViewItemQQfitsZModelQ3aCamaroQQhashZitem5 18e5829fcQQitemZ350280493564QQptZMotorsQ5fCarQ5fTr uckQ5fPartsQ5fAccessories
NBM2002WS6Vert
05-02-2010, 07:44 PM
I bought that DVD a while back just out of curiousity. Seems to provide very clear instructions and a lot of little tips that you wouldn't know just from poking around.
Good luck!
reelnauti
05-02-2010, 09:18 PM
The first thing you have to do is check the rear bow height and adjust the top pad as necessary. I am assuming you are doing the glass and the top also. then put the rear glass in according to the bow height work from the middle out. It is very difficult to get a top on to look good no wrinkles or bagginess. also make sure the glass is not to high or low for the top part it has to cover the top of the glass should be an overlap. After you are satisfied with rear glass. Start on the top at the rear bow again. center the top on the rear glass with the overlap. attach at the bow. work top now to the front. usually there are marks from the top manufacturer where the front should line up all the way up front. do the rear section from the bow to over where you attached the rear glass. I have done multiple tops and all are different. each top has it's own problems. Good Luck
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
