What fuel pump
Old 01-07-2004, 06:12 PM
goober35's Avatar
Default What fuel pump
I am starting to build my direct port system for my 250 shop. It is dual stage 100 out of the hole and when i hit second and adishanle(sp) 150. I need to know what fuel put to get so i can suport the system. I have been thinking of getting a pump for just the nitrous kit its self so i would have 2 fuel pumps but i know think that would be a good idea. If I just get a new pump and put it in will it be safe because i am running the 28lb injecters. So the only time i would use the exstra fuel pressure is at WOT.
Old 01-07-2004, 10:51 PM
taqwache's Avatar
you are definently in need of a seperate fuel system. Derty did a good write up on this. check it out.
https://ls1tech.com/forums/nitrous-oxide/125194-direct-port-stand-alone-fuel-writeup.html
