Why is my trans am side skirt bulging?
So today I used the jack that came with the car to change the wheel, and when I let it down, I noticed that my side skirt is now bulging out in one spot so that it isn't flush with the door. Any ideas why, and how to fix it?
pic in post #2
need to get the car up in the air and look to see what adjustments need to made.the plastic will eventually warp,and you can use the heat gun to work it back into the proper shape,but first you will need to try and straighten out the mounting location,to where the fender bolts to,where you jacked it up at.
make sense?
make sense?
It was actually right at the back of the passenger side. About 2 inches from the end of the side skirt.
