Drag Racing Tech
suspension setup help (beginner)
Old 04-22-2010, 10:18 PM
ls6firebird's Avatar
Default suspension setup help (beginner)
im very new to setting up a car, so im looking for some advice with my new setup. i read the sticky, started to understand, kept reading, and now i think im more confused than i was before.
i ordered a 9" from mwc with a 4.30 gear. i also ordered their adj tunnel mount tq arm and lca's. shocks are stock for now. the car is lowered on slp springs. it is full weight and m6. i will be running 26x11.5x15 slicks.
im not putting down huge hp numbers, so should i just set my pinion angle at 0? or should i put it somewhere around -1, or more?
should i start with the lca's in the top whole on the rear, and go from there, or should i go ahead and put them lower since the car sits so low?
i would reall appreciate any tips and advice. also, if anyone has a similar setup, i would be interested in what i can expect.
thanks
Old 04-22-2010, 10:47 PM
silverbeast's Avatar
Put them in the lowest hole and set the pinion at -2 and go from there. All cars are different but that is a good start.
Old 04-22-2010, 10:53 PM
alright thanks!
Old 04-23-2010, 06:48 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Your going to need Adjustible Shocks in the rear at minimum. The car will probably work so well your going to be bouncing off the rear end.
Do this. Get bright silver, some lipstick is optimal. Clean off the axle tube (if dirty) and where the bump stop would normally contact. Rub the lipstick on there or whatever that is greasy. IF there is contact after a run, then the body needs to get under control. Otherwise the weight xfer is not at all optimal.
Old 04-23-2010, 08:55 AM
7 Second Club
Phil99vette's Avatar
The best advice i can give you is the call Madman.
Old 04-23-2010, 02:49 PM
thanks for the tips! i will probably have at least rear shocks before i even have a chance to go to the track. i'll probably just pick up a couple used adjustable ones till i decide which ones i want to go with
Old 04-23-2010, 03:28 PM
nocooler's Avatar
Don't even try putting the lower control arms in the lowest hole with the stock shocks.
Trust me I have the same setup - but with 4.10's. The lowest hole gives you to much anti-squat. On a hard launch the tires would hook, bounce and unload, then hook and go.
https://ls1tech.com/forums/drag-raci...need-help.html
Moving the lower control arms to the stock position corrected this and the car started dead hooking.
Old 04-23-2010, 03:42 PM
wow i gotta figure out what shocks i want. from that video i think im gonna launch a lot harder than what i was expecting.
Old 04-23-2010, 04:56 PM
7 Second Club
AFCO shocks
Old 04-23-2010, 05:09 PM
Originally Posted by Phil99vette
AFCO shocks
can they be adjusted while on the car?
Old 04-23-2010, 05:26 PM
Bitemark46's Avatar
This man knows. We had a guy local that put it on the lowest bolt. Damn rear had over 6" of separation between the tire and fender on the hit.
Measure the center of the LCA mounting bolts to the ground for the front and rear bolts. They should be no more that 1.5" difference. The more parallel the LCA is more the LCA will want to push the car forward.
-Mark
Old 04-24-2010, 07:43 PM
also, just to make sure i understand adjusting correctly...when adjusting the tq arm and lca's, do u do all the adjusting with full weight on the suspension? or do you jack the car up, adjust, then put the car back down and then tighten everything up?
Old 04-24-2010, 07:49 PM
223HAWK's Avatar
You want to set the Pinion angle with weight on the suspension/rearend..if you can fit under the car without jacking it up thats the best way IMO..
Old 04-24-2010, 07:53 PM
i was planning to put blocks under all 4 tires so the car would be level. would there be anything wrong with that?
Old 04-24-2010, 07:59 PM
223HAWK's Avatar
I dont see why not, just make sure it cant fall on ya!!
Old 04-25-2010, 01:38 AM
Bitemark46's Avatar
The car should be loaded...WITH a driver in the seat. Try and find some blocks so you can have the car siting a good 10" off the ground to measure the LCA and the PA. Whenever you make any chances to the car try and do it like if you were at the staring line ready to race.
