Mr. B
04-23-2010, 01:18 AM
What would be the best application for this motor.. F/I, Power-Adder, Carb, or N/A?
If you had one- how would you use it for best results?
http://paceperformance.com/ProductImages/manufacturer/gm/images/19170112.gif
LSX 454 Crate Engine
An engine with 454 cubic inches will always be assosiated with higher performance Chevys, and that tradition continues with the all new LSX454 crate engine. We started with the new LSX bowtie block, stuffed it with an all-forged, super tough rotating assembly, and bolted on a pair of our new deep breathing LSX six-bolt cylinder heads.
The new LSX six bolt cylinder heads are based on the race-derived LS7 heads that help deliver more than 500 horsepower in the Corvette Z06. They enable tremendous low end torque and great high RPM power. The LSX 454 is delivered in long block form. It also comes dressed with great looking, all new orange powder-coated valve covers with 'LSX 454" logos engraved and painted in black.
Note:
Oil pan and oil pump pickup are not included. LSX valve covers do not have coil mount provisions, coils will need to be relocated
LSX454 Specifications
Engine type - LSX series Gen IV small block V8
Displacement - 454 CID (7.4L)
Bore & Stroke - 4.185" X 4.125" (106.3mm X 104.8mm)
Block - 19243172 LSX cast iron block with cross bolted 6 bolt main caps
Crankshaft - 19170391 Forged steel
Pistons - 19166958 Forged aluminum
Camshaft - Hydraulic roller - .635" / .635", 236 / 246 duration @ .050"
Cylinder heads - 19201806 Aluminum LSX- LS7 port with 70cc chambers
Valve size - 2.20" titanium intake, 1.61" exhaust
Compression ratio - 11.0:1
Rocker arms - 1.8:1 aluminum roller trunion
Reccomended fuel - 92 octane
Reluctor wheel - 58X
Note- Does not include intake, carb, oil pan, oil pump pickup, flexplate, ignition or front accessories
Note:
