Alternator bracket bolts
Old 04-23-2010, 06:21 AM
69blackwhss's Avatar
Default Alternator bracket bolts
hey guys i need some Alternator bracket bolts could u tell me what the size of the bolts are an the thread count is so i can get them at the hardwere store. an what length also thanks jason
the motor is a ls1 out of a 2000 camaro
Old 04-23-2010, 01:22 PM
bump..
Old 04-24-2010, 04:35 AM
bump..
Old 04-24-2010, 11:00 AM
99345hp's Avatar
I just used all ARP hardware to install an alternator on a boosted LS3 for a GTM at work, but it doesn't use stock brackets. For the life of me I cannot remember if it was 8 or 10mm, but definitely course thread. For the length, you should be able to use a tape measure and figure that out.
Old 04-25-2010, 11:13 PM
massls1guy's Avatar
As I remember it all the big bolts were the same length when I swapped my alternator. But my manual says they are a little different:
2 - M10x1.5x125
1 - M10x1.5x90
1 - M8x1.25x50 (rear bolt)
Old 04-26-2010, 01:53 AM
thanks guys thats what i was needing
Quick Reply: Alternator bracket bolts
