Drag Racing Tech
Removing the *tilt* steering wheel assembly to save weight?
Old 04-23-2010, 09:56 AM
CarolinaCamaro's Avatar
Question Removing the *tilt* steering wheel assembly to save weight?
this would be on a 2002 camaro z28. I have heard removing the tilt wheel assembly saves serious weight.
Old 04-23-2010, 10:12 AM
5.3LJimmy's Avatar
If you plan on swapping it for a race only type unit then it would shed some weight, but I don't know about that "serious weight". This would also require deleting the ignition, blinker, cruise, wiper, and headlight dimmer switches. Not exactly the setup you'd want for a street car. I wouldn't bother if you are talking about converting the stock tilt column to a non tilt type, however swapping the steering wheel and deleting the airbag is an easy way to lighten things up.
Old 04-24-2010, 10:47 PM
DaynNight's Avatar
where did you hear this?
Old 04-26-2010, 08:10 AM
Exclamation
from NLang (avatar) on a drag tech post on lowest race weight.
"Do you need a tilt-able steering column? You can buy a 4130 roller bearing column kit for $140 from autoweldchassis.com. I think I kicked 20-25lbs here"
Old 04-26-2010, 09:21 AM
Fireball's Avatar
I built my own tubular column and steering shaft...saves about 10 lbs over an OEM column (just the column, this doesn't include going to a racing steering wheel which is more weight savings)
Quick Reply: Removing the *tilt* steering wheel assembly to save weight?
