Burned out/busted blinker
Old 10-19-2002, 07:34 PM
2001SS#3013's Avatar
Default Burned out/busted blinker
I have had to replace my passenger side front blinker bulb 4 times now. Each time it either explodes or burns out. The socket it brown kinda burnt looking. What could be the problem. I have clear corners on, that wouldn't have anything to do with it would it? I need some help if you can give it to me. I am tired or replaceing bulbs. Thanks.
Old 10-19-2002, 10:22 PM
98,Ram,Air's Avatar
Default Re: Burned out/busted blinker
get a small candle and put it in place of the bulb.... <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old 10-20-2002, 10:14 AM
wrencher
wrencher's Avatar
Is water getting in there?
Old 10-20-2002, 11:02 PM
No water is getting in there that I know of. There is no cloudiness or condensation in the "housing" that I can see. It was suggested that I try to clean the socket really good. So I will try that.
Old 10-21-2002, 07:38 AM
WILWAXU's Avatar
Moving to appearence section.
Old 10-21-2002, 09:49 AM
chrswr5's Avatar
I have to bring up the water issue again....that really what it sounds like....maybe some water gets in there after you wash your car....the burnt look your talking about is what I was getting because my clear corners were leaking. Keep an eye one it...If you notice you you do accumulate water then click on this link for a thread with help on that issue.
-chris.
Old 10-21-2002, 04:07 PM
The Guy in MY 99TA's Avatar
I'll tell ya one thing. This corner park light lenses on a TA can be a MOTHER of a %^$@#^#$!#$%^#!^#$%#$^#$^#!$%^#$%#@$%!#@$%!#$^^. I mean I cannot keep condensation out of mine!!! It has gotten soooo bad that my connectors have started RUSTING!!! I'be been through about 50 bucks worth of bulbs! My next choice is to find a TA in a JUNK yard and get the whole assembly with the connectors and just go from there. I'm gunna seal em up REALLY good.
Josh S.
Old 10-21-2002, 10:05 PM
wrencher
wrencher's Avatar
If you suspect water infultration use die-electric grease in the socket. It will help keep terminals from corroding & keep heat transfer down.
Old 10-22-2002, 12:13 AM
Administrator
unit213's Avatar
Go to Autozone and ask for blinker fluid. You're probably running low. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Sorry, couldn't resist. A girl I know fell for that back in high school. She looked for 30 mins at Kmart for blinker fluid instead of a fuse. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
On a serious note, I think it's water causing it. Lots of people have had problems with moisture building up in their clear corners. I haven't had any problems with my clears.
Old 10-22-2002, 12:35 AM
I have already checked my blinker fluid. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> It is OK!
Quick Reply: Burned out/busted blinker
