6.0L out of 2007 Van?
Old 04-23-2010, 04:28 PM
AustinYukon's Avatar
Default 6.0L out of 2007 Van?
Found a dude selling a complete 6.0L out of an '07 or '08 Van.
Are these iron block, alum block? what heads? Are they worth getting?
Old 04-23-2010, 04:40 PM
blazinblue's Avatar
It more than likely is a LQ4. with 317 heads. These are good compression for boost. So yes, definitely worth getting.
Old 04-23-2010, 06:46 PM
87SS's Avatar
May be a LY6 6.0 iron block w/317 heads, that is where my motor came from (2008 van).
Old 04-23-2010, 08:49 PM
1quickirocz's Avatar
I thought the LY6 came with L92 heads and VVT from the factory??
Old 04-23-2010, 11:45 PM
spdracer256's Avatar
It does... but there is a catch. In 2007 Chevrolet used both a standard 6.0 (lq4) in the trucks marked classic and they used the ly6 with the l92 heads and vvt in the "new style" trucks. I'm not sure in vans so you'd have to do some research. If you go to buy a ly6, it is found in the new style or smooth door trucks. I used car-part.com to get mine.. $1500 complete with harness. Only has 17k on it.
Old 04-24-2010, 07:57 AM
87SS's Avatar
You are correct, not sure why I thought I had 317s.
Old 04-30-2010, 10:40 PM
Can anyone tell what motor this thing has by the VIN?
The VIN is:
1GAHG39U861189109
Old 04-30-2010, 11:05 PM
poweredbychevy's Avatar
it's a 2006 3500 van
Old 04-30-2010, 11:17 PM
What size did they normally come with? 6.0L?
Old 04-30-2010, 11:49 PM
yeah the 3500 had the 6.0
Old 05-01-2010, 07:31 AM
poconojoe's Avatar
The VIN is:
1GAHG39U861189109
8th digit is a "U" so its a 6.0
I don't think the Express vans got VVT, since most of them were sold as work vehicles
Old 05-01-2010, 11:23 AM
3pedals's Avatar
easiest way to tellwhat you have would be to look at the front of the heads and look at the head casting number. if you have 823 you have LY6 w/L92 heads and VVT, if 317, you have LQ4.
VVT definately comes on "work" vehicles.
Old 05-01-2010, 01:41 PM
Jimbo1367's Avatar
Look for this type of timing cover
http://www.mastmotorsports.com/page....Camshaft&id=30
ALSO........ IIRC if you look at the pass. side rear of the block.... if its a LY6 it says gen IV as the LY6 is a gen IV and the LQ4 is a gen III It might even say it on the drivers side front too.
Old 05-01-2010, 11:16 PM
3pedals's Avatar
my '07 LY6 says IV 6.0 on the drivers side front of the block
Old 05-02-2010, 09:30 AM
Jimbo1367's Avatar
My 08 LY6 says the same. Thats where I got this info
Old 05-04-2010, 12:34 PM
supershift67's Avatar
My 6.0 came out of a 2007 express van and it is a LQ4 with 317 heads on it. It runs good so if you could pick it up it would be worth it.
Old 05-08-2010, 08:50 PM
w4625's Avatar
Default Dbw
Which year 6.0 Vans came with DBW?
Old 05-09-2010, 09:57 AM
Not sure when they started DBW but mine is.
Quick Reply: 6.0L out of 2007 Van?
