LivernoisMotorsports
04-23-2010, 05:29 PM
Today, I was able to go to Milan Dragway to make a few passes in James' (Midgard) Camaro.
Runs were made on 20" Nitto Drag Radials at 16 lbs. Race weight was 4,130 lbs.
The car is very consistent, I ran several 10.5X passes and a best of 10.44 @ 134.29 mph. My best 60' was 1.55, but it would spin after the 60' and on the 1-2 shift, so I lifted quickly and got back into it. James ordered a set of Bogarts, so we should get some real times out of it once they arrive.
Modifications are:
Livernois Motorsports 419ci Stroker Longblock
Livernois Motorsports CNC LS3 Cylinder Heads
Livernois Motorsports Ported Supercharger Manifold
Livernois Motorsports Ported Throttle Body
Livernois Motorsports LS-Series Dual Valve Spring Package
Livernois Motorsports Custom Ground Camshaft
Magnacharger MP2300 Supercharger
Water-to-Air Intercooler
Livernois Motorsports 8-Rib Drive Kit
Fuel System Upgrades (Incl. 60# Injectors, High Volume Dual Fuel Pump, & Boost-A-Pump)
Rotofab Cold Air Intake
NGK TR6 Spark Plugs
160 Degree Thermostat
3-Bar Map Sensor
Built A6 Transmission
Hendrix HD Axles
Kooks Stainless 1 7/8" Headers
Kooks Stainless Catted Connection Pipe
Corsa Exhaust
Livernois Motorsports Custom Dyno Tune
We've found similar packages offered by our competition for 10's of thousands of dollars more. Call or pm today for pricing or to schedule an appointment.
Video
Milan Dragway - 10's on 20's (http://www.youtube.com/watch?v=K6QUBn1PpS8&fmt=22)
Thank you
Regards,
Rick LeBlanc
Modifications are:
NGK TR6 Spark Plugs
3-Bar Map Sensor
Hendrix HD Axles
Corsa Exhaust
Video
Thank you
Regards,
Rick LeBlanc
