ECU for drive by wire
I plan on running a drive by wire setup. I currently have an 04 LQ4 with drive by wire throttle body and LS1 intake.
I realize that many vehicles did not come with DBW. Does it matter which ECU I go after? Can Non-DBW ECUs be re-flashed to incorporate it?
Thanks again,
Thanks again,
So, from what I gather, it would be wise to search for the 12200411 PCM.
This PCM has the hardware to drive the IAC on cable throttle bodies, and can be used for DBW throttle bodies, depending on the firmware installed.
Can anyone confirm this?
