weird sound coming from engine (video inside)
sounds like the right side, maybe toward the rear?
http://s629.photobucket.com/albums/u...t=IMG_0802.flv
I have the same noise in my 2000 Z28. it only happens when the engine is still warm after a drive and starting it up and it will make sound for less than a minite and then go away. any luck with that yet?
u can also use a screwdriver or piece of wood and start putting it in diff spots on the motor with ur ear up against the screwdriver that will help u pin point where the noise is coming from.. good luck
