Drag Racing Tech - Guys running 28" fronts come on in please
tektrans
04-25-2010, 06:15 PM
Do you have to trim anything to make them fit? Can you still run the inner fenderwells or do you have to remove them?
spoonraker
04-25-2010, 07:27 PM
My 26'' fronts are really close to rubbing I can't imagine that you could run a 28'' front without rubbing. Haven't personally tired it though so take that for what it's worth.
tektrans
04-25-2010, 08:08 PM
Yeah I noticed that on mine also. Less so with skinnies I'm thinking but I'd like to see if Coach or Tosto or someone else can guide me here.
94Z28rag
04-25-2010, 09:38 PM
What's the advantage to 28" in the front vs 26"? Especially on a 15" wheel?
Wicked94Z
04-25-2010, 11:32 PM
increased rollout... better ETs, we're talking a few hundredths.
Ken95Z28
04-26-2010, 12:18 PM
They are very close, I had to trim mine to make them fit.
I also removed the inner fender plastic piece as well. It was leaving rub marks on them. Must have been either from the launch or hard breaking on the big end.
AChotrod
04-26-2010, 12:33 PM
Pretty sure Gizmo runs 28s up front and I seen his car pull nasty wheelies.
JL ws-6
04-27-2010, 12:40 PM
You have to remove all the inner fender plastic, the tires will rub all over the place if you don't.
1cdub
04-27-2010, 06:24 PM
Plastic inner fender liners are gone and i'm slowing rubbing the paint off the steel support under the location of the stock battery. Also be sure to massage the sharp lip directly over the centerline of the wheels where the fender and innerfender structure are bolter together. Once you are under there it will be very obvious what you need to remove. I just took a flapper wheel and contoured the the edges to match the opening of the shock towers on the inside. Here is a still shot with 28's on the front and 29.5's on back.
http://i4.photobucket.com/albums/y149/BillyBob750/Picture095.jpg
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
