Want a 1.3x 60 foot time. How?
First of all, yes I have done a search and read all the stickies.
I look at the cam only times and see 60 foot times in the 1.3 range and want to get there. I feel like I have all the ingredients including afco DA's all around, new slicks and fully adjustable and solid mounted (rod ends) suspension. My best 60' is 1.459 and that was with stock rear shocks and worn out slicks.
Several weeks ago I was able to manage a 1.460 and that was with new rear Afco DA's and slicks with about 6 passes on them. I am leaving off the 2-step at 5500-5700 rpm, and probably need to bump that up a bit.
Any advice is appreciated. I am kind of getting desperate.
Thanks
Thanks
A good 60' doesn't win races
I didn't say that, someone else did...anyway
Do you have a vid of one of your launches and how much rwhp do you make?
I'm not a 6 speed guy myself but I think you may be leaving at too low an rpm.
Will the suspension hold a higher rpm launch and will it bog is what I'd like to know.
Thanks for the response.
441 rwhp
Yeah it certainly bogs. It seems to be a fine line between getting a bit of tire spin and more of a dead hook.
Unfortunately I don't have any videos.
441 rwhp
What rpm are u crossing traps at? Maybe a bit more gear would keep u from bogging.
The bog is certainly hurting the 60'.
I wonder if 441 rwhp through an M6 is enough hp to cut a 1.3 60'?
Yeah you might want to launch a lil harder if it is bogging. I have a few questions though. What is the fascination with a 1.3 60 ft and what gear are you running? What is the weight of your car?
Alex that has the black ws6 with the Cartek package on his car ran 10.32 @ 132 w/ a 1.43 60ft. He has 4.56 gears in his car. I think he is launching a lil above 6 grand not sure though.
I think to see a 1.3 you are going to need more leverage in getting off the line which means more gear, more motor or a higher launch rpm. A 346 is harder to get enough torque out of to produce that 60 in a heavy car. How light does it have to be I don't know. My buddy's T/A weighed 3480 with the pass. seat out and back seat out, no spare and 150lb driver 4000 stall and 3.73 gear and best he could muster was 1.43
Thanks again for the replies guys.
I guess a 1.38 60' is as good as it gets for a cam only car, at least that is what the cam only fastest list shows.
I am crossing the traps at redline which is 7200 rpm.
The car has 4:56 gears.
The car weighs just a hair under 3000 lbs.
I guess the next time out I will bump the RPM up and see what happens. I am just a but paranoid about breaking something.
Internet Mechanic
With the 6 speed, you need to leave as hard as you can.
Have you considered a GTO style gear set in the trans? That should be the ticket. I would first stop using the 2-step and see how you can manage it and if you get close to that goal. Throw in the better trans and then go from there. 2-steps are nice but with my exp working with a m6. It needs to be @ or near the limiter.
Best part is the 1:1 gear stays the same.
To be honest, if you're worried about breaking stuff, you'll never get faster. Sometimes you gotta let 'em hang out. If you're bogging, there is an issue. You need to get up to 6K on the launch or up the tire pressure.There is usually a fine line between a spin and a bog.
Internet Mechanic
You guys have more ***** than me!! I guess I am a cheap *** and need to grow a set. Mike c. Launching at 6600!!!! Good for you! Those are some good numbers. What does the car run in the 1/4?
Thanks again.
Thanks again.
Al
