Boot Retainer Broke - Any aftermarket Fix?
Old 04-25-2010, 08:27 PM
nimrod.sixty9's Avatar
Default Boot Retainer Broke - Any aftermarket Fix?
Just like the sixer did Cheap *** plastic (or expensive $30)...
Anyone do anything at home/DIY type of deal? I dont want to waste any money on these things to have them just break again...
Old 04-25-2010, 08:51 PM
Low N Slow's Avatar
I epoxied a piece of wire over the break and it's been holding it together for 5 years.
Redline Accessories sells a wire version that won't break if you don't want to fix the old one.
Old 04-25-2010, 09:27 PM
99FormulaM6r's Avatar
There's a guy on here named Farmer or Farmer2 or something that did it too
Old 04-26-2010, 01:18 AM
Just checked redline and it seems they only sell boots, not the retainers.
Unfortunately I just got the car and nothing came with the boot. Maybe Ill grab the remaining peices from the sixer.
The one from the sixer has multiple breaks.. What should I do with the wire??
Old 04-26-2010, 01:42 AM
Low N Slow's Avatar
http://redlinegoods.com/Camaro9802shiftboot.shtm
Scroll to the bottom of the page.
If you want to fix yours, I cut a fairly stiff piece of wire about 2 inches long, if you look at the retainer it's cross section is kind of like an L shape, shape the wire and lay it inside the L so it extends on both sides of the break and cover with epoxy.
Old 04-26-2010, 03:31 AM
THANK YOU!!!!
I cant believe they want less for thier metal one than the ppl selling the shitty plastic ones! wOOt!
Old 04-26-2010, 11:41 AM
Save the manuals!
wssix99's Avatar
Chemically weld it with ABS cement for less than $5: https://ls1tech.com/forums/manual-tr...fter-boot.html
Quick Reply: Boot Retainer Broke - Any aftermarket Fix?
