ls1 oil pan for 69 camaro?
Old 04-26-2010, 02:26 AM
69blackwhss's Avatar
Question ls1 oil pan for 69 camaro?
hey guys am doin a ls1 out of the 2000 camaro an its goin into a 69 camaro. What is the best oil pan to get. i have looked all over an found alot but just dont know what one too get! i was thinkin bot going with the s&p ls1 oil pan that they hack on an re weld which one is like 260.oo with me giving them my oil pan. an there is one on ebay that is a all new oil pan that is from retoLs.com here is the link but it is 420.00 http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
an i have asked someone who has got one an said that its not as low as it says but its a nice work of art.
i want one that is not goin to hang down low to the ground like what people say the lh8 hummer pans do.
so if anyone could help i would be greatfully.
jason
Old 04-26-2010, 03:38 AM
an i have a stock k member on my 69 camaro btw. sorry
Old 04-26-2010, 06:11 AM
SamHatco's Avatar
jason
Do the Street & Performance pan, that's what I did. They do a good job converting the pan.
Sam
Old 04-26-2010, 06:50 AM
hotrodvince's Avatar
here try one these http://www.jegs.com/i/Moroso/710/201...oductId=763991 http://www.jegs.com/i/Moroso/710/20140/10002/-1
Old 04-26-2010, 08:07 AM
Jimbo1367's Avatar
I checked out your pic in yer signature. Looks nice. Any more (better) pics?
Old 04-26-2010, 03:08 PM
Sam
thanks sam so how much oil does it hold now tho? just asking.
Old 04-26-2010, 03:09 PM
i want to stay away from a non oil filter pan but thanks for the help an links!
Old 04-26-2010, 03:10 PM
thanks brother an hell ya i got more lol i have had the camaro since i was 17 an am 26 now what pics u want to see an ill load them up
Old 04-26-2010, 04:44 PM
Indyjc's Avatar
Do you already have an ls1 oil pan? Why don't you just notch it? There was a sticky on this. It cost me about 50.00 to have it cut and rewelded. No problems for 2 years. Good luck
Old 04-27-2010, 04:41 AM
ya i have the ls1 oil pan when i got the motor. but i just dont want to cut up my kmember just me tho. thanks for the help tho
Old 04-27-2010, 07:11 AM
SamHatco's Avatar
I don't remember. You can call S&P and they will tell you.
Sam
Old 04-27-2010, 07:25 AM
Sam
ok lol an were did u get ur wire harness at? are id u did it ur self? sorry for all the questions but just want to get it rite the 1st time u know
thanks
jason
Old 04-27-2010, 07:57 AM
duhr8m's Avatar
Default pan
I cut mine back to lip in floor of pan and removed about 1 1/2 inches up to flat from front to back. It fits great and did not have to move pick up and can use the baffel. it was 5.5 qts now its 5qts. motor is also further back but still 2 inches firewall clearance. I'll get pics. alt still clears frame and manifolds clear steering box, no a/c.
Old 04-27-2010, 02:44 PM
did u happen to use the hooker header mounts? thats the ones am goin to use were an goin with hooker headers for the motor. an i wish i could but it my self but i cant re weld it i dont have the rite welder on hand!!
Old 04-27-2010, 04:37 PM
bczee's Avatar
you can also check out the new cast LHX pans that RetroLSX is selling.. Aftermarket one would get good clearance as well. You can Search and see the threads already posted, I have one for my 71 Nova project.
Old 04-27-2010, 06:49 PM
SamHatco's Avatar
thanks
jason
I used the 04 GTO wire harness along with the BCM, PIM and Throttle Control Module. Hey no problem about the questions, glad I might be some help.
Sam
Old 04-27-2010, 06:52 PM
gMAG's Avatar
I have the Hooker Motor Mount Adapter Plates combined with Energy Suspension Motor Mounts (#3.1114G). The Energy Suspension mounts come with an extra metal plate which is not to be used in this application. (the extra plates cause the engine not to fit properly within the mounts).
I also notched my oil pan in anticipation of the oil pan not clearing the steering or the member.
After placing my 98 LS1 in the engine bay, I realized that the oil pan never needed to be altered one bit. With the Hooker Motor Mount Adapters & the Energy Suspension mounts, the engine sits perfectly, and the Hooker longtubes sit just right too!
No cutting, No welding, and No spending!!!
Glenn
Old 04-27-2010, 06:53 PM
gMAG's Avatar
Also, I have a 67 RS...should be exactly the same...67-69. Verify this!
Old 04-27-2010, 06:59 PM
gMAG's Avatar
Almost forgot...because the engine will sit slightly lower, the bottom screw of the alternator, plus two of the webbed fins on the bottom of the alternator will interfere with the k-member (just barely). I ground them just enough so that there is safe clearance between the member and the alternator.
In addition, there is not enough room for the plastic air vent behind the alternator. I trimmed it just enough to clear.
Here's one other issue...Where they exit the firewall, the Heater Tubes may not have enough clearance to clear the rear of the passenger head. A fellow LS1'er gave me this idea...He converted to a 67-69 Big-Block heater core & cover. The BB heater has tubes which exit from the fender side of the heater core cover. You can always retain your small block heater core and cover if you ever convert back!
Glenn
Old 04-27-2010, 08:09 PM
Indyjc's Avatar
I'm not talking about notching your k-member, I'm talking about notching your oil pan.
Quick Reply: ls1 oil pan for 69 camaro?
