PCV Valve
Old 04-27-2010, 03:38 AM
UKDriver's Avatar
Default PCV Valve
Does anybody know what the heavy duty cable is connected/wrapped around the PCV Valve?
It connects to the block at the other end. It looks like an earth lead but doesn't seem to have any electrical function - perhaps static?? Can you live without it?
File Type: pdf
Old 04-27-2010, 04:32 AM
sjsingle1's Avatar
it is designed to transfer heat from the block to the valve to reduce condensation inside the valve.......dont know how well it works.......but thats it
Old 04-30-2010, 03:02 AM
UKDriver's Avatar
Thanks for the reply - makes sense.
I read on one forum that it was for cooling - which didn't make any sense wrapped in a rubber boot attached to the block.
