worried
worried
I'm stumped!! I have a clunking noise sort of like when brake pads are worn out and become loose, but louder. It seems to be coming from the rear of the car. I have replaced all of the bushings, shocks, brakes and rotors. Everything I check is tight. I jacked the car up and put stands under the axles and removed the tires and I could find nothing loose. I removed the calipers and rotors and was looking at the axles and noticed that I have maybe 1/32" of play on both sides if I pull and push on the axle. Is this Normal or do I have a problem in the rear? I'm afraid to drive the car and it is my daily driver. Anyone know what this is? Thank You for any Help.
Yes I looked at the U-joints and they are good. I was going for the tourque mount originally but it looks good also. There is no vibration at speed 85 mph and the car handles great. Somthing is just loose, when I come out of my driveway i come out at an angle because of the shape of the driveway I can hear a pretty loud noise. The exhaust system is tight, I just don't see it?????
-checked the gear oil
-opened the cover on rear ?
- checked lca bolts, might be loose...
-pulled axles ?
- stock torque arm broke?
- panhard bar bolts?
-bushings might be worn out
just some ideas of a clunking sound....
-pulled axles ?
Well 100 miles and no noise maybe it's gone I hope. I was just concerened about play in the rear axel, but you say a little is normal. I did have a lot of clanking coming from under my car before I replaced all of the bushings. That's why i was shocked to hear a noise again.
