Help with wifes car cd player install
Old 04-27-2010, 02:04 PM
99Transamls1's Avatar
Default Help with wifes car cd player install
Ok I attempted to install a dual cd player in my wifes 2003 cavalier I have the gm 2000 interface wiring harness. Matched up all wiring by the colors only wiring left was blue amp wire and an orange wire in the harness. the chimes work but cd player will not turn on. Anyone know what might be the problem ?
Old 04-27-2010, 02:42 PM
jimmy 2 Times's Avatar
are you getting 12v from the red wire on the radio with the key switched on?
Old 04-29-2010, 08:46 AM
Yes I am
Old 04-29-2010, 06:29 PM
omarrakeen's Avatar
the orange wire could b the power for the memory of the radio so u dont have to set the radio everytime u switch it on i THINK..check the radio manual again..and the blue amp wire should b connected to the powerd control of ur radio if it has an amp output!
Old 05-01-2010, 02:20 PM
Well I know the yellow wire is the memory cause it has a fuse in it the orange is titled the accessory wire the interface chimes adcwols just when I wire it to the radio it will not turn on like it's not getting power
