LS1 Crankshaft freeze plug?
Old 04-27-2010, 03:15 PM
98cobrakillata's Avatar
Default LS1 Crankshaft freeze plug?
Hey guys I'm trying to get a new freeze plug for the crank. The plug that sits behind the pilot bearing.
Does anyone know either the size, the dorman part number, or the gm part number?
Old 04-27-2010, 05:41 PM
Lambert695's Avatar
I think the small ones are 16mm and the big ones are 30mm? Someone will correct me if im wrong.
Old 04-27-2010, 09:07 PM
massls1guy's Avatar
Part # 24502262 is listed at the bottom of this thread, I think it's correct:https://ls1tech.com/forums/manual-tr...-screw-up.html
I would just get it at the stealership if I was you.
Quick Reply: LS1 Crankshaft freeze plug?
