Drag Racing Tech
lt1- 6 liter swap wiring questions
Old 04-27-2010, 04:01 PM
bobby32's Avatar
Default lt1- 6 liter swap wiring questions
so i have a 94 lt1 and i out an lq9 in it with a 2001 engine harness but the chasis harness is driving me nuts im not sure exactly what it came off of.. it might be a firebird or trans am harness nut these are the four connectors givin me trouble they are located right under the steering cloumn and could possibly connect in that area so any help would be appreciated thanks
Attached Thumbnails lt1- 6 liter swap wiring questions-2010-04-26-16.28.12.jpg   lt1- 6 liter swap wiring questions-2010-04-26-16.28.40.jpg   lt1- 6 liter swap wiring questions-2010-04-26-16.29.04.jpg   lt1- 6 liter swap wiring questions-2010-04-26-16.29.16.jpg
Old 04-27-2010, 05:26 PM
Mikey 97Z M6's Avatar
You might have better luck posting this in the Conversions/Hybrid section. They do alot of harness/wiring conversions over there.
Mike
Old 04-27-2010, 05:46 PM
bobby32's Avatar
ya i tried that unfortunatley i had no response to my post so im just tryin to throw it out there and hopefully someone might have some insight
Old 04-28-2010, 09:09 AM
InsaneAuto86's Avatar
Look to be radio/cd player related.
Old 04-28-2010, 03:09 PM
5.3LJimmy's Avatar
I'm going strictly off of memory but I say the first two go to the clutch switch and the second two are for the brake light switch. I'm pretty sure the little gray plug is the one I have a paper clip jumper in so my car will crank with the TH350 swap.
Old 04-28-2010, 04:43 PM
bobby32's Avatar
awesome ill check that out thanks a ton
Old 04-29-2010, 11:02 AM
sweetbmxrider's Avatar
first pic, gray 2 wire connector: Brake Light Switch C1
blue 4 wire connector: Stop Lamp/TCC Switch Connector C2
if you can get better shots of the other connectors, that would help. that or type out the way they appear.
guessing here, blue 8 wire connector last pic:In-Line Connector C211 (has to do with tps and throttle relaxer motor?)
last pic, gray? 10 wire connector:In-Line Connector C212
i can post schematics of the connectors if you want, hope this helps some.
Old 04-29-2010, 12:58 PM
bobby32's Avatar
Ahhhh that's perfect man that's exactly what I was looking for. If u do have the schematic that would help even more I appreciate it
Old 04-29-2010, 06:02 PM
C211 - (8 cavities) Forward lamp to traction control module jumper harness, under the left side of the IP, near the kick panel.
the other one seems to be c212, which would make total sense
C212 - (10 cavities) Forward lamp to traction control module jumper harness, under the left side of the IP, near the kick panel
let me know if you want the other two connectors as well or anything else for that matter
Quick Reply: lt1- 6 liter swap wiring questions
