Water pump question
Old 04-27-2010, 11:15 PM
metalman's Avatar
Smile Water pump question
I need to move the outlet of the waterpump ( the one on top of the pump on a truck style pump) to make my radiator hose fit just right. I have heard you can heat the pump and rotate the insert and let it cool and it will work as good as new. I would appreciate is someone could help me out on this as a new pump would not be cheap if I mess this one up. Thanks in advance.
Old 04-28-2010, 12:42 AM
2XR95Z28's Avatar
i heated with a propane torch and got mine to move, its not very easy but if you get it hot enough it will move. I used a rubber mallet after heating it up to rotate it... Head it for a long time lol...
Old 04-28-2010, 08:06 AM
Jimbo1367's Avatar
aluminum disapates heat very well. huh? LOL.
Old 04-28-2010, 10:19 AM
ErikSOCAL's Avatar
I came across a thread where one member heated the area around the outlet with a torch and slipped a jack handle or pipe over the fitting to turn it.
Old 04-28-2010, 10:48 AM
Jimbo1367's Avatar
I would think rotating it like 2XR95Z28
stated would look best and more "factory"
Old 04-28-2010, 09:10 PM
metalman's Avatar
Default water pump
I have heated the pump and rotated the fitting and now I have seepage??? Any suggestions on this?
Old 04-28-2010, 10:24 PM
Finesse615's Avatar
Quick Steel
