scites
04-27-2010, 11:59 PM
i have owned this car since march of 2006, it was bone stock when i paid 12k forit. sincethen i have installed the following
ENGINE
HKE 402ci
11.5.1 compression
LQ9 block
callies dragon slayer crank
lunati pro bullit rods
ross -8cc pistons
custom cam 600 610 lift 24x 25x dur 112+5
melling high volume oil pump
hex adlust timing chain
arphead and main stud
Trick flow 225cnc heads
milled to 61 cc
upgraded 650 liftsprings
caddy lifters
smith bro push rods
yella terra rocker arms
ported fast 90mm and TPIS 90mm TB
42lb hr injectors
plus what ever else im forgetting
i have well over 13k just in the motor
fuels system
42lb injectors
racetronex pump and wire kit
billet high flow fuel rails
trans
4l60e rebuilt by a local guy with ALTO mater rebuild kit
corvette servo
beast sunshell
trans go shift kit
fuddle HPS 4400 stall
Deral trans pan with cooling tubes
trans cooler mounted to front of radiator
rearend
moser housing with 31 spline moser axles
nodular iron center with auburn 31 spline posi unit 4.11 gears
LCA relocation brackets welded on
tie down rings welded on
less then 800 miles on rear end.
Suspension
BMR sub frame connectors
BMR pan hard bar
lakewood LCA
QA1 springs
comp engineering drag shocks in the rear
short tunnel mount torque arm
wheels
convo pro's
15x4 front with 195 radial
15x8.5 rear with M/T 26/10.5 et drags
also have stock wheels
exhaust
hooker 1 3/4 long tubes
i have a few different exhaust for the car. a true dual kit and a ORY and cat back set up
NITROUS
Nitrous express LS1 EFI wet kit
upgraded solinoids good to 250hp shot
msd mindow switch
msd timing tuner
WOT switch
all nitrous switches are in the ash tray and out of sight.
I also have HP tuner pro that may come with it for the asking price
the interior looks bone stock the bodys in in outstanding shape. there is a 1in scratch on the drivers side from a shopping cart. i HAVE NOT SPRAYED THE MOTOR WITH NITROUS. I had the kit installed and blew up the cam only motor and havenot installed the rest of the stuff on the new motor. i HAVE NOT ran this motor at the track. i know the old motor went 6.9's in the 1/8 with a shitty 1.8 60ft time on BFG DR's and the new motor should be an easy 6.0 to 6.3's on motor..with the bottle this car will have no problem getting into the sub 9's in the 1/4 mile. the car requires a little more tunning butat the moment it still gets about 16 MPG
id like to get 19K or trade a DD plus cash..or a nice vette..i just want something i can drive 500 miles if i dont think i would have a problem driving this car 500 miles put i would be deff and i dont want to put miles on it with a 4400 stall..
Tom
850-377-7653
ENGINE
HKE 402ci
11.5.1 compression
LQ9 block
ross -8cc pistons
milled to 61 cc
caddy lifters
smith bro push rods
42lb hr injectors
fuels system
42lb injectors
trans
corvette servo
beast sunshell
trans go shift kit
rearend
Suspension
BMR pan hard bar
lakewood LCA
QA1 springs
wheels
convo pro's
exhaust
NITROUS
msd mindow switch
msd timing tuner
WOT switch
Tom
850-377-7653
